Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Problem replacing image in dialog box
1 REPLY 1
brad.bylls
138 Views, 1 Reply
In my script I start with just a drop down in a dialog box.
I start with all image command inputs as isVisible = False.
When the user selects an item, an image is then changed to isVisible = True and displayed.
If the user changes their mind and selects something different, the new image is displayed in the dialog but the original image doesn't disappear with isVisible = false.
Does something else have to be done?
Brad Bylls
1 REPLY 1
brad.bylls
in reply to: brad.bylls
Finally figured it out.
Just a programming problem.
Brad Bylls
