Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Problem extruding multiple faces in a row
2 REPLIES 2
tiktuk
131 Views, 2 Replies
I'm trying to make a box smaller by extruding each of its faces inwards (cutting) by different amounts. I let the user select each face first (can hopefully automate most of this selection work later) and the do the extrudes on the faces. The problem is that after one or a few extrudes I get an error:
RuntimeError: 2 : InternalValidationError : input
The strange thing is that it varies how many extrudes that succeeds, even for the same input values and selections.
Any ideas?
Here is the code:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def extrude_face(
    face: adsk.fusion.BRepFace,
    distanceExpression: str,
    name: str = ''
) -> adsk.fusion.ExtrudeFeature:
    Make a box smaller by extruding the sides inwards.
    app = adsk.core.Application.get()
    design = app.activeProduct
    rootComp = design.rootComponent
    distance = adsk.core.ValueInput.createByString(distanceExpression)
    # Create the extrusion.
    extrudes: adsk.fusion.ExtrudeFeatures = rootComp.features.extrudeFeatures
    ext = extrudes.addSimple(
        face, distance, adsk.fusion.FeatureOperations.CutFeatureOperation
    ext.name = name
    return ext
def run(context):
    ui = None
    try:
        ui = app.userInterface
        faces = []
        faces.append(
            ui.selectEntity('Select the front face', 'PlanarFaces').entity
        faces.append(
            ui.selectEntity('Select the top face', 'PlanarFaces').entity
        faces.append(
            ui.selectEntity('Select the back face', 'PlanarFaces').entity
        faces.append(
            ui.selectEntity('Select the bottom face', 'PlanarFaces').entity
        faces.append(
            ui.selectEntity('Select the left face', 'PlanarFaces').entity
        faces.append(
            ui.selectEntity('Select the right face', 'PlanarFaces').entity
        extrude_face(
            faces[0], '-10 mm', name='Front'
        extrude_face(faces[1], '-10 mm', name='Top')
        extrude_face(faces[2], '-20 mm', name='Back')
        extrude_face(
            faces[3], '-10 mm', name='Bottom'
        extrude_face(faces[4], '-15 mm', name='Left')
        extrude_face(
            faces[5], '-5 mm', name='Right'
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
2 REPLIES 2
kandennti
in reply to: tiktuk
Hi @tiktuk -San.
I think if I select all and extrude later, I lose the second face after the first extrusion.
I rewrote the run function to extrude each time a face is selected.
def run(context):
    ui = None
    try:
        dataLst = [
            ("Front", "-10 mm"),
            ("Top", "-10 mm"),
            ("Back", "-20 mm"),
            ("Bottom", "-10 mm"),
            ("Left", "-15 mm"),
            ("Right", "-5 mm"),
        for name, valueStr in dataLst:
            try:
                face: adsk.fusion.BRepFace = ui.selectEntity(
                    f"Select the {name.lower()} face",
                    "PlanarFaces"
                ).entity
                extrude_face(face, valueStr, name)
            except:
                break
        ui.messageBox("Done")
    except:
        if ui:
            ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
tiktuk
in reply to: kandennti
Thanks, @kandennti, that is a good workaround 🙂
