Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Print() problem
1 REPLY 1
brad.bylls
382 Views, 1 Reply
Print() problem
Working on a script and having a problem.
app = adsk.core.Application.get()
        ui  = app.userInterface
        size=ui.inputBox('Screw size','SHCS','')
This creates an input dialog box.
I enter: 1/4
Later in the code I read a csv file:
        dlg = ui.createFileDialog()
        dlg.title = 'Open CSV File'
        dlg.filter = 'Comma Separated Values (*.csv);;All Files (*.*)'
        if dlg.showOpen() != adsk.core.DialogResults.DialogOK :
            return
        filename = dlg.filename
        f = open(filename, 'r')
        line = f.readline()
        data = []
        while line:
            pntStrArr = line.split(',')
            for pntStr in pntStrArr:
                data.append( str(pntStr))
            if len(data)>=5 :
                screw = data[0]
                string = (data[0], data[1], data[2], data[3], data[4])
#                if screw = size :
                print(size)
                print(screw)
                #input(string)
            line = f.readline()
            data.clear()
        f.close()
The csv file contains lines:
1/4,.375,.5,.75,1/4
1/2,.625,.75,1.0,1/2
and so on.
The red lines:
print(size)     Prints:1/4
print(screw)  Prints: ['1/4', False]
If it is reading 1/4 from the file, why is it printing ['1/4', False] ?
Brad Bylls
Tags (2)
1 REPLY 1
ekinsb
in reply to: brad.bylls
The inputBox method returns two values; the value the user entered and a boolean indicating if the dialog was canceled or not.  In Python this is returned as the single result which because there are two values is returned as a list.  You can see this in the documentation for the inputBox method (http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-110bf712-8527-4ccd-a11d-f7266d69773e).
You should be doing something like this:
result = ui.inputBox('Screw size', 'SHCS', '')
# Check to see if the dialog was cancelled.
if result[1] == True:
    return
size = result[0]
Brian Ekins
Mod the Machine blog
