Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
(PostProcessor) createFormat inherit bug?
0 REPLIES 0
Message 1 of 1
cmantunes
96 Views, 0 Replies
Hello!
I stumbled on what I believe is an implementation bug on createFormat when using inherit. Here is an example:
let f1 = createFormat({decimals:3, type:FORMAT_REAL});
writeln("f1 = " + f1.format(42)); // "f1 = 42."
let f2 = createFormat({inherit:f1});
writeln("f2 = " + f2.format(42)); // "f1 = 42.000"
Format f2, which strictly inherits from f1, ends up producing an output as if minDigitsRight were set to 3.
BTW, I'm using post revision 45946.
Thanks!
Carlos
Labels (1)
0 REPLIES 0
