Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Post Processor
4 REPLIES 4
johnvgallagher
336 Views, 4 Replies
Post Processor
I am curious to know if there are post processors for Emco pc55 mills and lathes. Does anyone know if these have been mad available?
Thanks, John
4 REPLIES 4
brianrepp
in reply to: johnvgallagher
Hey @johnvgallagher - have you seen this post on the CAM forums?  Might give a bit more insight on the posts and where to look for more info.
ArjanDijk
Hi @johnvgallagher,
I have both machines running on WinCAM, I import the code using an adjusted standard post.
The post you need depends on the control you have (siemens 810/840D/ Heidenhain/Fanuc). What control do you run?
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
johnvgallagher
in reply to: ArjanDijk
Yes, both machines run on Fanuc
johnvgallagher
Arjancncmachinework,
Both my Emco mill and lathe use GE Fanuc Series O. How can I get the post
for these machines?
John
