Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Possible to toggle marking menu sample from hotkey? Using Addin?
1 REPLY 1
dseeni
234 Views, 1 Reply
If I package the marking menu as an addin, I can add it. But I would like to trigger the addin run and stop contexts so that the marking menu will deactivate.. is this possible?
Ultimately I would like to create my own marking menus, and trigger them from hot key sequenes. Is this possible with the way addins are designed?
I don't get how to stop the addin from a key press..is there an example?
1 REPLY 1
OceanHydroAU
in reply to: dseeni
This might help you?
https://modthemachine.typepad.com/my_weblog/page/11/
It's a way for an add-in to run arbitrary things - maybe that also include stopping stuff
