Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
possible error in sample script
1 REPLY 1
peterpieter
308 Views, 1 Reply
Hi there
I'm learing API scripting and stumble over an error in this script
http://help.autodesk.com/cloudhelp/ENU/Fusion-360-API/files/Arc3D_Circle3D_getData_Sample.htm
On lines 21, 22,48 and 49 there is made use of   ...    ent.Object. ...
This does not work on my configuration.
But when I change it to
… ent.entity …
Then it works like a shine.
greets,
Tags (1)
1 REPLY 1
neil.liu
in reply to: peterpieter
Many thanks for reporting the issue to us. We will fix it soon and you will see the update in the coming release.
