Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Positioning Manipulator
4 REPLIES 4
BlackPrism
474 Views, 4 Replies
I'm trying to align an angle manipulator to a sketch construction line after selecting a joint origin for the manipulators origin, but just cannot seem to get a vector that works....... nothing I try will align to the sketch line.
Can anyone point me in the right direction?
// Activate and deactivate the input controls and their manipulators for the position joint if (firingInput->id() == "elementSelection") { selCmd = inputs->itemById("elementSelection"); if (selCmd->selection(0)) { locationOrigin = selCmd->selection(0)->entity(); elementManipulatorOrigin = locationOrigin->geometry()->origin(); Ptr<Vector3D> yDirection = locationOrigin->geometry()->secondaryAxisVector(); Ptr<Vector3D> zDirection = locationOrigin->geometry()->thirdAxisVector(); elementAngle->isEnabled(true); //elementAngle->setManipulator(elementManipulatorOrigin, yDirection, zDirection); elementAngle->setManipulator(elementManipulatorOrigin, Vector3D::create(0, 1, 0), Vector3D::create(0, 0, 1)); //elementName->isEnabled(true); //elementLength->isEnabled(true); //elementLength->setManipulator(elementManipulatorOrigin, Vector3D::create(0, 2, 0)); } else { elementName->value(""); elementName->isEnabled(false); elementLength->value(0); elementLength->isEnabled(false); elementAngle->value(0); elementAngle->isEnabled(false); } }
4 REPLIES 4
marshaltu
in reply to: BlackPrism
Unfortunately it was a bug in our side. I logged UP-35806 in our internal system to track it.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
gavin9537
Hi. Would you mind posting a bit more of your code? I can't answer your question, but I am trying to work out how to activate the rotation input control as I cannot find it in the object tree.
BrianEkins
in reply to: gavin9537
The rotation manipulator is part of the AngleValueCommandInput object.  You get the graphic manipulator and also a field in the dialog where the user can enter the angle.
Brian Ekins
BlackPrism
Sorry for the delay in my reply and hopefully Brian's reply has given you what you need. My source changed considerably after the original post, as the issue I encountered turned out to be a bug and so I'm not sure its going to help. I believe the bug has been fixed, but haven't check as our current project is for a client using SolidWorks.
As Brian says, look at the AngleValueCommandInput object its pretty easy to use. I was positioning the manipulator based on point selection and then using it to set the length and angle of a sketch line; the command being called from a custom drop down menu embedded in the Fusion toolbar.
Hope this helps.
