Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
popup info to setup sheet
1 REPLY 1
TechrimStandards
184 Views, 1 Reply
Hello, so I am trying to create a popup that has a dropdown with checked boxes when you click post process and then put those checked boxes onto my setup sheet. How would I go about doing this and do you have any examples to send over?
1 REPLY 1
goyals
in reply to: TechrimStandards
May be you can consider writing a command and in command input change handler, you can save the string in to excel sheet. You can consider using XlsWrite python module to write the information in excel set up sheet.
Shyam Goyal
Sr. Software Dev. Manager
