Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
populating drop down boxes with default values
brad.bylls
brad.bylls
I am working on an api UI that has six drop down boxes.
What I am trying to do is when the user selects an item from the first drop down box, (which gathers data from a csv file) the other dropdown boxes are populated with a default value, but are still able select a different value from the dropdown list.
I have been working a couple of days on this and just can't figure it out. I'm sure it is pretty simple, but . . .
The complete code is attached.
Any help appreciated.
Thank you.
ps. I know the code is a little sloppy, but I want to get it to work first.
Brad Bylls
OceanHydroAU
This fragment of code from one of my projects might help?
if cmdh[v]['type']=='RadioButtonGroupCommandInput' or cmdh[v]['type']=='ButtonRowCommandInput' or cmdh[v]['type']=='DropDownCommandInput': # button / Dropdown
    if cmdh[v]['type']=='DropDownCommandInput' and dlg[v].selectedItem is None:
        dlg[v].listItems.add(" ",True)  # Need to first create the selected object before we can select a different one
    if dlg[v].selectedItem.index >= 0:
        dlg[v].listItems[ dlg[v].selectedItem.index ].isSelected=False # Un select previous
    dlg[v].listItems[setting].isSelected=True # Select preset
That demo's adding/populating, as well as selecting stuff
