Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I am working on an api UI that has six drop down boxes.
What I am trying to do is when the user selects an item from the first drop down box, (which gathers data from a csv file) the other dropdown boxes are populated with a default value, but are still able select a different value from the dropdown list.
I have been working a couple of days on this and just can't figure it out. I'm sure it is pretty simple, but . . .
The complete code is attached.
Any help appreciated.
Thank you.
ps. I know the code is a little sloppy, but I want to get it to work first.
Solved by OceanHydroAU. Go to Solution.
This fragment of code from one of my projects might help?
if cmdh[v]['type']=='RadioButtonGroupCommandInput' or cmdh[v]['type']=='ButtonRowCommandInput' or cmdh[v]['type']=='DropDownCommandInput': # button / Dropdown
if cmdh[v]['type']=='DropDownCommandInput' and dlg[v].selectedItem is None:
dlg[v].listItems.add(" ",True) # Need to first create the selected object before we can select a different one
if dlg[v].selectedItem.index >= 0:
dlg[v].listItems[ dlg[v].selectedItem.index ].isSelected=False # Un select previous
dlg[v].listItems[setting].isSelected=True # Select preset
That demo's adding/populating, as well as selecting stuff
