Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Populate Fusion 360 "Favorites" Material Library Using A Python Script
1 REPLY 1
isocam
85 Views, 1 Reply
Can anybody help?
Is it possible to populate Fusion 360 "Favorites" material library using a python script?
For example, add new materials to the library.
Many thanks in advance!
Darren
1 REPLY 1
BrianEkins
in reply to: isocam
Here's a small sample that adds to the materials to the Favorites list.
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        lib = app.materialLibraries.itemByName('Fusion 360 Material Library')
        aluminum = lib.materials.itemByName('Aluminum 7075')
        app.favoriteMaterials.add(aluminum)
        gold = lib.materials.itemByName('Gold')
        app.favoriteMaterials.add(gold)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
