Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
poor performance when i make a gear
4 REPLIES 4
pegurilucas
157 Views, 4 Replies
before the latest update my pc was performing really well in fusion, after this update, some things improve even more, but when i  create a spur gear the performance drops hard to like... 1...2 fps its really anoying  i hope that this can be fixed, because i work with gears... a lot
My sistem specs are: -Ryzen 1200 @3.6ghz
- rx580 8gb
-16gb ram @3200mhz
-240g ssd
-motherboard gigabyte AB350-DS3H V2
4 REPLIES 4
pegurilucas
in reply to: pegurilucas
before everyone stars telling me this, yes i already have the latest drivers of EVERYTHING xd 🙂
BrianEkins
Are you talking about the spur gear add-in that's delivered with Fusion?  I didn't run it just before the latest update to be able to compare, but when I run it now after I created the first gear, it takes a fraction of a second to create additional gears.  The first gear probably took 2-3 seconds.
Brian Ekins
pegurilucas
in reply to: BrianEkins
yes with the add in script, but even after i create a new file and i make a gear..... the performance drops hard
BrianEkins
Maybe some others on the forum can try creating a gear and let us know how their performance is.  It's working the same as before for me.
Brian Ekins
