Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Point3D.create makes z coordinate negative before placing point
6 REPLIES 6
dahousecat
526 Views, 6 Replies
I've made a very simple script to place a point at 1, 1, 1.
When I run it I see a point has been created at 1, 1, -1.
Why is the z axis been made negative?
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        # Get the root component of the active design
        rootComp = design.rootComponent
        # Create sketch
        sketches = rootComp.sketches
        sketch = sketches.add(rootComp.xZConstructionPlane)
        # Create point
        testPosition1 = adsk.core.Point3D.create(1, 1, 1)
        testPoint1 = sketch.sketchPoints.add(testPosition1)
        # Test values
        print('x: ' + str(testPoint1.worldGeometry.x))
        print('y: ' + str(testPoint1.worldGeometry.y))
        print('z: ' + str(testPoint1.worldGeometry.z))
        # Outputs
        # x: 1.0
        # y: 1.0
        # z: -1.0
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The Fusion 36o UI also reports the point is at Z -1.
6 REPLIES 6
MichaelT_123
in reply to: dahousecat
Hi Mr. DaHouseCat,
... just have started fusiventure...?
Consider changing 'Z' to 'Y'.
Regards
MichaelT
PS. Nice smile though :).
MichaelT
JesusFreke
Hmm, yeah. It looks like the sketch's axis has been flipped. rootComp.xZConstructionPlane.geometry.uDirection is (0, 0, 1), but sketch.yDirection is (0, 0, -1).
I find that... surprising. If you specify a ConstructionPlane as the basis for a sketch, I would expect the sketch to have the same axis as the reference plane.
JesusFreke
in reply to: JesusFreke
I suspect it's a consequence of the default "y-up" view, which I always found... strange. I always use z-up, which makes much more sense to me. But anyway, if you have y-up enabled, and position the viewport so that +x is to the right, then +z is down. So when you add a sketch like this, "up" (positive y) in the sketch is in the -z direction.
I can confirm that if you have z-up enabled, adding a sketch to the xY plane has the coordinate space you would expect 🙂
dahousecat
Thanks, and I agree - very strange that Z up is not the default!
Hi, how did you solve this ?
I'm creating a 3D point to 1,1,1 and it appears at 1,1,-1. And the UI also states the z coordinate is negative. I also have sketch.yDirection.z = -1
I have Z-up preference set, so what should I do now ?
Hi @candice.pimenta9E4XT .
By using the Sketch.modelToSketchSpace method, you should be able to create a point at the desired location.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-dfec5579-3ee5-432b-80d9-50710515bd71
def run(context):
    ui = None
    try:
        # Create sketch
        # Create point
        # Test values
        app.log(f'{testPoint1.worldGeometry.asArray()}')
        # use modelToSketchSpace
        modelToSketchPoint = sketch.modelToSketchSpace(testPosition1)
        testPoint2 = sketch.sketchPoints.add(modelToSketchPoint)
        app.log(f'modelToSketchSpace:{testPoint2.worldGeometry.asArray()}')
    except:
        if ui:
