Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Please Update Spyder
1 REPLY 1
collegeresidence
206 Views, 1 Reply
You are using such an old version of Spyder that the developer can't remember details in order to help.
It keeps spitting up an error dialog every time I try to run a script, that I have to dismiss. Here, the developer says that only happens in old versions, but since this isn't a normal program installation, I cannot hope to update that complicated installation hiding in the Windows %AppData% directory along with Fusion 360.
https://github.com/spyder-ide/spyder/issues/5524
1 REPLY 1
Thank you for the remainder. We have had a task to be logged as UP-34823 in our internal system. We will reprioritize the task with other API works.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
