Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Please clarify Sketch.offset documentation
1 REPLY 1
gscotti
220 Views, 1 Reply
I'm really confused about what directionPoint means. Does it mean if it is inside the loop the offset is inwards aod if it is outside it is outwards? In this case, what does it mean to have a negative offset value?
1 REPLY 1
marshaltu
in reply to: gscotti
"directionPoint" was designed for specifying the direction of offset. Sometimes it is difficult to define the offset direction if the curves are not a loop. For example: for a single line, api clients would have no idea which direction offset line will go with if we only give positive/negative offset value. In UI side, the offset preview can give the hint of direction when users input positve/nagetive offset value.
For general purpose, Sketch.offset API would depend on "directionPoint" to decide offset direction, accept only positive offset value and ignore negative one users give.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
