Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Physical Interface - Midi/OSC
2 REPLIES 2
edoardo.sattin
1649 Views, 2 Replies
Hi there!
2 days ago I had an idea: controlling variables/parameters via a midi or OSC interface.
That could be very useful in order to explore different shapes in a fast and intuitive way.
Below, a video demonstration.
I checked online but couldn't find anything. As you can see in the video, there's just a software, Rhino (natively not-parametric), that via Grasshopper and another plugin can control shapes via midi controls.
Now, the developing part:
I'm learning javascript as my first programming language and I am very interested in adding a controller in my design workflow. I'd like to connect physical devices like nanoKONTROL or apps like TouchOSC to Fusion.
Do you think it is possible, via a script or add-in to do something like that? If so, are you interested in helping? Do you have any suggestion?
Thanks for reading!
Have a nice day!
2 REPLIES 2
ekinsb
in reply to: edoardo.sattin
That's an interesting project but I think you may be better off using Python instead of JavaScript.  Python is a better choice when programming Fusion anyway and after doing a brief search on the web I'm not sure there is a JavaScirpt integration to the devices you listed.  I did see some experiments but they were for Node and the JavaScript in Fusion is running in a browser, not Node.  I did find a Python library for TouchOSC. I didn't dig deep enough to see which version of Python but it's recent enough that hopefully it's for Python 3.
https://www.acmesystems.it/touchosc
Brian Ekins
Mod the Machine blog
edoardo.sattin
in reply to: ekinsb
Thank you very much for your suggestions and sorry for the late answer!
As soon as I learn a bit of Python I'll start the project. Again, suggestions are well accepted!
See you soon!
