Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Path from Spline? - How to get a Path, or maybe BRepFace/Profile from a SketchFittedSpline object?
2 REPLIES 2
OceanHydroAU
170 Views, 2 Replies
I'm trying to surface-loft non-flat splines, but the loftSections.add() method wants different input.
It works fine manually in the UI.
I've created two non-planar sections like this:-
foilobj=sketch.sketchCurves.sketchFittedSplines.add(points)​
They look like this in debug:
<adsk.fusion.SketchFittedSpline; proxy of <Swig Object of type 'adsk::core::Ptr< adsk::fusion::SketchFittedSpline > *' at 0x1a6426d50> >
I'm attempting to do something like this:-
loftInput = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
loftSectionsObj = loftInput.loftSections
loftSectionsObj.add(foilobj)​
but:-
RuntimeError: 3 : Invalid entity type: entities the a BRepFace, Profile, Path, SketchPoint, ConstructionPoint, or an ObjectCollection containing a contiguous set of Profile objects that defines the section.
I tried browsing the object (no obvious things in there) and I tried foilobj._get_geometry() (same problem).
From the above, it looks like I need either Path or maybe BRepFace (The *Point options aren't relevant, and Profile probably expects something flat, which these are not, and I'd rather not patch them all into faces if I can avoid that).
Does anyone know how I go from my "foilobj" (sketch.sketchCurves.sketchFittedSplines.add(points)) to a Path or similar?
Here's my input (also showing the rails I need):-
And what that looks like manually "Patched":
Screen Shot 2021-02-01 at 4.31.02 pm.pngScreen Shot 2021-02-01 at 4.31.29 pm.png
Labels (1)
2 REPLIES 2
OceanHydroAU
in reply to: OceanHydroAU
I wondered if the path wasn't automatically created from the spline, and so I tried this:
adsk.fusion.Path.create(foilobj, 0)
which got me a step further - that might turn out to be the answer? (if yes, I'll report back)
OceanHydroAU
OK - yep - the above worked:-
loftSectionsObj.add( adsk.fusion.Path.create(foilobj, 0) )​
Posting this here for future users, since google found me nothing...
