Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Paste a body from clipboard?
9 REPLIES 9
Message 1 of 10
hanskellner
1238 Views, 9 Replies
I'm attempting to duplicate a selected body using the API.  I've found that BRepBody supports cut and copy to the clipboard.  But how do I then paste from the clipboard? I haven't found any access to the clipboard or any other way to paste.
Or is there some other way, using the API (Javascript preferably), to duplicate a body?
Thanks!
Hans Kellner
Senior Manager, Principal Engineer
9 REPLIES 9
Message 2 of 10
jan_priban1
in reply to: hanskellner
Hello Hans,
I have similar sniplet/script which makes new instance of component. If you will find it useful...
Regards
Jan Priban, Autodesk
//Author-JP
//Description-tocite schody
function run(context) {
    "use strict";
    if (adsk.debug === true) {
        /*jslint debug: true*/
        debugger;
        /*jslint debug: false*/
    var ui;
    try {
        var app = adsk.core.Application.get();
        ui = app.userInterface;
        var product = app.activeProduct;
        var design = adsk.fusion.Design(product);
        if (!design) {
            ui.messageBox('No active Fusion design', 'No Design');
            return;
        // Get the root component of the active design.
        var rootComp = design.rootComponent;
        var occs = rootComp.allOccurrences;
        // Gather information about each unique component
        var count = occs.count;
        ui.messageBox(count.toString(), 'count');
        //var comp = occs.item(0).component;
        //var jmeno = comp.name
        //ui.messageBox(jmeno,'name');
        // Create a new occurrence.
        var trans = adsk.core.Matrix3D.create();
        // Create a new occurrence for the component, offset by 15 cm in the X direction.
        trans.setCell(0, 3, 15.0);
        var newOcc = rootComp.occurrences.addExistingComponent(occs.item(0).component, trans);
        //ui.messageBox('Hello script');
    catch (e) {
        if (ui) {
            ui.messageBox('Failed : ' + (e.description ? e.description : e));
    adsk.terminate();
Message 3 of 10
hanskellner
Thanks for the suggestion but I need to duplicate a body. I'm still hoping there's some twisted solution buried in the API.
Hans Kellner
Message 4 of 10
ekinsb
I thought this might be a workaround but it doesn't quite work.  The BrepBody object does support a copy method which copies it to the clipboard but there's not a paste method anywhere.  I thought I could just invoke the "Paste" command, which I can but doing a past of a body also puts you into the move UI so it doesn't work as expected.  Anytime you start mixing the API with normal commands and the UI you never know what will happen.  I think we need to add something like a copoyTo method on the body where you can specify the component you want to copy to.  A general copy and paste functionality isn't all that useful through an API because of it's context sensitivity.
The code below does create a copy but I also wanted to get that copy and then perform some other operation, a move in this case.
    "use strict";
        debugger;
    var ui;
    try {
        // Have a body selected.
        var body = ui.selectEntity('Select a body', 'SolidBodies').entity;
        // Copy the body to the clipboard.
        body.copy();
        // Call the paste command.
        var pasteCmd = ui.commandDefinitions.itemById('PasteCommand');
        pasteCmd.execute();
        // Start the select command to exit out of the move command that was started automatically
        // as a result of the paste.
        var selectCmd = ui.commandDefinitions.itemById('SelectCommand');
        selectCmd.execute();
        // Get the last body created in the active component.
        var comp = app.activeEditObject;
        var newBody = comp.bRepBodies.item(comp.bRepBodies.count-1);
        ui.messageBox(newBody.name);
        // Move the body.
        var input = adsk.core.ObjectCollection.create();
        input.add(newBody);
        var transform = adsk.core.Matrix3D.create();
        transform.translation = adsk.core.Vector3D.create(10,0,0);
        var moveFeatures = comp.features.moveFeatures;
        var moveInput = moveFeatures.createInput(input, transform);
        moveFeatures.add(moveInput);
    catch (e) {
        if (ui) {
    adsk.terminate();
Brian Ekins
Mod the Machine blog
Message 5 of 10
hanskellner
in reply to: ekinsb
Ok, I'll take a look at this solution and see if it will work.
Hans Kellner
Message 6 of 10
taxponation
in reply to: ekinsb
Is there any update on this issue? I am trying to make add-in to duplicate selected object by specified patterns. I wrote simple python scripts to duplicate selected object by reference to ekinsb's javascript code as follows.
bodyInput = cmd.commandInputs.itemById('SolidBodySelect')
body = bodyInput.selection(0).entity
bodyName = body.name
# Copy body to clipboard
body.copy()
pasteCmd.execute()
selectCmd.execute()
ui.messageBox(str(comp.bRepBodies.count))
# Create collection
col = adsk.core.ObjectCollection.create()
col.add(newBody)
# Apply Move
vector = adsk.core.Vector3D.create(0, 1, 0)
transform.translation = vector
moveFeats = app.activeProduct.rootComponent.features.moveFeatures
moveFeatureInput = moveFeats.createInput(col, transform)
moveFeats.add(moveFeatureInput)
 When I run this code, the move operation is executed before the paste operation. I guess this is because the paste operation is executed asynchronously while the move operation is asynchronously. Is it right?
It would be great if you could teach me how to duplicate and move object propery using API.
Thanks 🙂
Message 7 of 10
ekinsb
in reply to: taxponation
Since I wrote the original response the API has been enhanced and you can now directly copy a body.  The code below demonstrates this by copying the selected body 5 times in the model X direction.
def run(context):
    ui = None
    try:
        des = adsk.fusion.Design.cast(app.activeProduct)
        root = des.rootComponent
        body = adsk.fusion.BRepBody.cast(ui.selectEntity('Select a body', 'Bodies').entity)
        # Check to see if the body is in the root component or another one.
        target = None
        if body.assemblyContext:
            # It's in another component.
            target = body.assemblyContext
        else:
            # It's in the root component.
            target = root
        # Get the xSize.
        xSize = body.boundingBox.maxPoint.x - body.boundingBox.minPoint.x
        # Create several copies of the body.
        currentX = 0
        for i in range(0,5):
            # Create the copy.
            newBody = body.copyToComponent(target)
            # Increment the position.
            currentX += xSize * 1.1
            trans.translation = adsk.core.Vector3D.create(currentX, 0, 0)
            # Move the body using a move feature.
            bodyColl = adsk.core.ObjectCollection.create()
            bodyColl.add(newBody)
            moveInput = root.features.moveFeatures.createInput(bodyColl, trans)
            moveFeat = root.features.moveFeatures.add(moveInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Message 8 of 10
taxponation
in reply to: ekinsb
Wow great! It works fine in my environment. Thanks Smiley Very Happy
Message 9 of 10
This works for bodies, but how would that work form components and sketches.
Any help on that, how do i change the ObjectType
Message 10 of 10
When creating a copy of a component you're actually creating a new occurrence.  The way to do that is demonstrated in the second post above.  As far as copying sketches, it's only possible to copy sketches when working in Direct modeling model ("Do not capture design history").  The primary focus of the API has been on Parametric mode since that's what's used the most and the API doesn't currently support the ability to copy a sketch.
Brian Ekins
