Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Parameters dialog box: reference names for columns/levels displayed (Python)?
2 REPLIES 2
atherisinnovations
601 Views, 2 Replies
What is this level of the model parameters dialog called? I mean what is its proper API reference (python)? Is it referenced as a feature or is it something else? In the timeline it is a name, but in the modelParameters list it is something else (modelParam.name returns a d-number, not the feature as it is named onscreen).
 Does hierarchy go something like this?:
Model Parameters>>Component>>(Feature?)>> (FeatureRole?)>ParameterName>ParameterUnit>ParameterExpression ??
Thanks!
2 REPLIES 2
I've also done some exploring and edited the DumpParameters script written by Brian Ekins, but I still can't output the on-screen names of the 'feature' level of the Parameter Dialog window. Here's the script as I have re-worked it:
#Author-Brian Ekins
#Altered by Stephen Brzykcy
#Description-Dumps out parameter info to a specified csv file.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get the name of the file to write to.
        fileDialog = ui.createFileDialog()
        fileDialog.isMultiSelectEnabled = False
        fileDialog.title = "Specify result filename"
        fileDialog.filter = 'CSV files (*.csv)'
        fileDialog.filterIndex = 0
        dialogResult = fileDialog.showSave()
        if dialogResult == adsk.core.DialogResults.DialogOK:
            filename = fileDialog.filename
        else:
            return
        des = app.activeProduct
        result = 'Component,Type,CreatedBy,Role,Expression,Unit,cmORrad,ParamName\n'
        # Get the data for all user parameters.
        for userParam in des.userParameters:
            result += ('UserComp,User,NA,' + userParam.comment + ',' + userParam.expression +
                           ',' + userParam.unit + ',' + str(userParam.value) + ',' + userParam.name + '\n')
        for comp in des.allComponents:
            for modelParam in comp.modelParameters:
                result += (comp.name + ',Model,' + str(modelParam.createdBy) + ',' + modelParam.role + ',' + modelParam.expression +
                           ',' + modelParam.unit + ',' + str(modelParam.value) + ',' + modelParam.name + '\n')
        output = open(filename, 'w')
        output.writelines(result)
        output.close()
        ui.messageBox('File written to "' + filename + '"')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Here is a snippet of the csv output:Screen Shot 2018-05-02 at 10.58.54 AM.png
This does ok. I would still like to have the on-screen names of the features referenced by their dimensions, not just the component. Can anyone help?
 Thanks!
-Stephen
In most cases, you can get reference names by following codes if the parameters belong to objects represented in Timeline. If not, you may have to cast "CreatedBy" property of parameter to concrete objects and get names of those objects.
Marshal
def run(context):
    ui = None
    try:
        design = adsk.fusion.Design.cast(app.activeProduct)
        root = design.rootComponent
        modelparams = root.modelParameters
        for modelparam in modelparams:
            ui.messageBox('name: {}, role: {}, createBy: {}'.format(modelparam.name, modelparam.role, modelparam.createdBy.timelineObject.name))
    except:
        if ui:
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
Technology Administrators
