Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Parameter/Dependencies for Custom Compute Feature
3 REPLIES 3
akshaypat08
111 Views, 3 Replies
I'm in the process of creating a custom feature that involves screws. The user has to select what screw type and screw head type in a drop down menu. For the custom compute class, how would I add this menu as a parameter/dependency?
3 REPLIES 3
Hi @akshaypat08 ,
I understand from your question you might need to command inputs of type DropDown:
- first one for screw type
- second one for screw head
Does the values on the second one would change according with what the user select on the first one, or are they independent of each other?
Please clarify in order to help you with instructions about the implementation.
Jorge
The two are independent. I realized that I could simply add them as dependencies and that I've been overthinking this. Thank you for responding though!
BrianEkins
in reply to: akshaypat08
I believe the best approach, in this case, would be to save the screw type and screw head type as custom named values. There's a small section in the Custom Features documentation about this. The hard part will be changing the geometry when the user edits either one of the types.
Brian Ekins
