Announcements
Organizing Dimensions using Python Script Fusion 360
sidharthbabu8
sidharthbabu8
Hey Everyone,
Hope you guys are doing great!
I am trying to generate dimensions of a STP file which have no design history (STP file is generated from Inventor and is opening on Fusion). So, my current situation is my python is able to sketch out all the geometry on the Face that I preselect. Its bringing in all the wanted and unwanted data/dimensions. Also these dimensions are overlapping. I will post the python code below. The issues that I am facing right now which need help is:
  • keep the dimensions organized, make the non radial dimensions bring outside the sketch.
  • keep at least a min of 15mm distance between dimensions.
  • avoid overlapping
  • currently python gives the vertical distance from the edge (horizontal distances are from nearest points) , however due to some reason, the dimensions are from the furthest edge possible. I am thinking about getting the dimensions from the closest corner of the sketch so its practical for operators to check the position of holes and other features
  • Also, if the part is inclined, the program is not able to sketch any circles due to which I am not getting any hole dimensions
This is my current situation. What you see here is on the STP file.
I don't have much knowledge in Python due to which I use ChatGPT along with what I know. Please find the code below:
import adsk.core
import adsk.fusion
import adsk.cam
import traceback
def create_offset_plane(selected_face, root_comp):
    try:
        # Create a construction plane at 0 offset from the selected face
        plane_input = root_comp.constructionPlanes.createInput()
        plane_input.setByOffset(selected_face, adsk.core.ValueInput.createByReal(0))
        return root_comp.constructionPlanes.add(plane_input)
    except Exception as e:
        # Log the error for debugging
        adsk.core.Application.get().userInterface.messageBox(f"Failed to create offset plane: {str(e)}")
        return None
def is_duplicate_dimension(existing_dimensions, point_one, point_two):
    for dimension in existing_dimensions:
        if dimension.objectType == adsk.fusion.SketchDimension.classType():
            if dimension.parameter.isDriven:
                continue
            if (dimension.startPoint.geometry.isEqualTo(point_one) and
                dimension.endPoint.geometry.isEqualTo(point_two)) or (
                dimension.startPoint.geometry.isEqualTo(point_two) and
                dimension.endPoint.geometry.isEqualTo(point_one)):
                return True
    return False
def add_dimensions_to_sketch(sketch, selected_face):
    try:
        # Get the existing dimensions in the sketch
        existing_dimensions = sketch.sketchDimensions
        # Iterate over each edge of the selected face
        for edge in selected_face.edges:
            geometry = edge.geometry
            if geometry.curveType == adsk.core.Curve3DTypes.Line3DCurveType:
                # Handle line edges
                startPoint = edge.startVertex.geometry
                endPoint = edge.endVertex.geometry
                sktStartPoint = sketch.modelToSketchSpace(startPoint)
                sktEndPoint = sketch.modelToSketchSpace(endPoint)
                sketchLine = sketch.sketchCurves.sketchLines.addByTwoPoints(sktStartPoint, sktEndPoint)
                sketch.areDimensionsShown = True
                midPoint = adsk.core.Point3D.create(
                    (startPoint.x + endPoint.x) / 2,
                    (startPoint.y + endPoint.y) / 2,
                    (startPoint.z + endPoint.z) / 2
                try:
                    if not is_duplicate_dimension(existing_dimensions, sktStartPoint, sktEndPoint):
                        sketch.sketchDimensions.addDistanceDimension(
                            sketchLine.startSketchPoint,
                            sketchLine.endSketchPoint,
                            adsk.fusion.DimensionOrientations.AlignedDimensionOrientation,
                            midPoint
                except RuntimeError as e:
                    pass  # Suppress the error message related to over-constraint
            elif geometry.curveType == adsk.core.Curve3DTypes.Circle3DCurveType:
                # Handle circular edges
                circle = edge.geometry
                centerPoint = sketch.modelToSketchSpace(circle.center)
                radius = circle.radius
                sketchCircle = sketch.sketchCurves.sketchCircles.addByCenterRadius(centerPoint, radius)
                # Find the furthest point from the circle's center
                furthest_point = None
                max_distance = -1.0
                for sketchLine in sketch.sketchCurves.sketchLines:
                    for sketchPoint in [sketchLine.startSketchPoint, sketchLine.endSketchPoint]:
                        distance = centerPoint.distanceTo(sketchPoint.geometry)
                        if distance > max_distance:
                            max_distance = distance
                            furthest_point = sketchPoint
                if furthest_point:
                    # Determine orientation based on relative positions
                    if abs(furthest_point.geometry.x - centerPoint.x) > abs(furthest_point.geometry.y - centerPoint.y):
                        # Horizontal dimension
                        orientation = adsk.fusion.DimensionOrientations.HorizontalDimensionOrientation
                    else:
                        # Vertical dimension
                        orientation = adsk.fusion.DimensionOrientations.VerticalDimensionOrientation
                        sketchCircle.centerSketchPoint,
                        furthest_point,
                        orientation,
                            (sketchCircle.centerSketchPoint.geometry.x + furthest_point.geometry.x) / 2,
                            (sketchCircle.centerSketchPoint.geometry.y + furthest_point.geometry.y) / 2,
                            0
                # Add radial dimension
                sketch.sketchDimensions.addRadialDimension(
                    sketchCircle,
                        centerPoint.x + radius,
                        centerPoint.y,
                        centerPoint.z
            elif geometry.curveType == adsk.core.Curve3DTypes.Arc3DCurveType:
                # Handle arc edges
                arc = edge.geometry
                centerPoint = sketch.modelToSketchSpace(arc.center)
                startPoint = sketch.modelToSketchSpace(arc.startPoint)
                endPoint = sketch.modelToSketchSpace(arc.endPoint)
                radius = arc.radius
                startAngle = arc.startAngle
                endAngle = arc.endAngle
                sketchArc = sketch.sketchCurves.sketchArcs.addByCenterStartSweep(centerPoint, startPoint, endAngle - startAngle)
                    sketchArc,
                        centerPoint.y,
                        centerPoint.z
        adsk.core.Application.get().userInterface.messageBox(f"Error in add_dimensions_to_sketch: {str(e)}")
def run(context):
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = app.activeProduct
        # Get the root component of the active design
        root_comp = design.rootComponent
        # Get all selected entities (faces) from the user's selection
        selected_entities = ui.activeSelections
        selected_faces = []
        # Filter and collect selected faces
        for selection in selected_entities:
            if isinstance(selection.entity, adsk.fusion.BRepFace):
                selected_faces.append(selection.entity)
        # Check if faces are selected
        if selected_faces:
            # Create a new offset plane at 0 offset from the selected face
            offset_plane = create_offset_plane(selected_faces[0], root_comp)
            if offset_plane:
                # Create a new sketch on the offset plane
                sketches = root_comp.sketches
                sketch = sketches.add(offset_plane)
                # Add dimensions to the sketch based on the selected face
                add_dimensions_to_sketch(sketch, selected_faces[0])
        adsk.core.Application.get().userInterface.messageBox(f"Error in run: {str(e)}")
# Entry point of Fusion 360 script
if __name__ == '__main__':
    if ui:
        # Prompt the user to run the script
        ui.messageBox('Click OK to run the script.')
        try:
            run(None)
            adsk.core.Application.get().userInterface.messageBox(f"Unhandled exception: {str(e)}")
Can someone please help me with this?
Replies (0)
