Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Open file. Check available "design data"
1 REPLY 1
345 Views, 1 Reply
project = app.data.dataProjects.item(0)
folder = project.rootFolder
fileUploaded = folder.uploadFile(str(path)) #Upload file
#---Wait when fileUploaded.uploadState==1
documents = app.documents
open(fileUploaded.dataFile,True)
 I upload .dwg file and check upload status. When file uploading complete i try open it but has error in Fusion 360
How I can check when "Design data" is available?
1 REPLY 1
liujac
There is no other way to check if the uploaded data is available. Ideally, the uploaded data should be available when the upload state is changed to adsk.core.UploadStates.UploadFinished. So it looks like a defect to me. I logged a defect (UP-30672) in our internal system for further investigation. One workaround for now is to sleep several seconds before opening the document. Thanks for reporting this issue.
Jack
Technology Administrators
