Only Write Certain Parameters To A CSV File
Can anybody help?
I have the following script that outputs Parameters to a CSV File.
#Author-Darren James Smith
#Description-Export Parameters To File
import adsk.core, adsk.fusion, adsk.cam, traceback, csv, subprocess
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
filename = "C:\Windows\Temp\Parameters.txt"
writeParametersToFile(filename)
#subprocess.run('C:\Program Files\PMM\Configure.exe')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def writeParametersToFile(filePath):
design = app.activeProduct
with open(filePath, 'w', newline='') as csvFile:
csvWriter = csv.writer(csvFile, dialect=csv.excel)
for param in design.allParameters:
try:
paramUnit = param.unit
except:
paramUnit = ""
csvWriter.writerow([param.name, param.expression])
I have a set of 25 parameters but I only want to save certain parameters to the CSV file.
The parameters that I want to save are:
CentreX
CentreY
DimensionA
DimensionB
DimensionC
Can anybody modify the script, above, to only output the parameters that I want?
Many thanks in advance!!!!
Darren
