Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
One or more operations are still being generated / Initialization Fails
2 REPLIES 2
sfotis
150 Views, 2 Replies
Hope you're doing well!
I am using the api to post process couple of setups, and when I'm trying to do this for more than one setups, I am getting the following errors...
When using the postProcess method from the NcProgramm object, I'm getting:
"One or more operations are still being generated", while when using postProcess or postProcessAll attribute from CAM object, I'm getting: "Initialization Fails".
What can I do about it??
I tried adding sleep time in-between the individual operations, before the invoking the method, but the issue remains.
Thank you in advance!
2 REPLIES 2
Jorge_Jaramillo
in reply to: sfotis
It isn't clear in your post how the toolpaths are being generated.
If you use any of the CAM.generateToolpath 's methods, all of the return a GenerateToolpathFuture which can be used to track the toolpath's generation progress, as described in the documentation:
Can you explain better your workflow or even better can you share your code to generate toolpaths and post-process them?
I believe than using just sleep() isn't enough to wait for the toolpaths for being completed.
Jorge Jaramillo
sfotis
in reply to: sfotis
Hello Jorje,
Adding this apparently resolved issues.
        while not toolpath.isGenerationCompleted:
            time.sleep(.5)
