Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Occurrence Appearance Name
9 REPLIES 9
Message 1 of 10
gvisca44
340 Views, 9 Replies
Trying to write myself a script that will read a CSV file that contains a list of components - and their desired Appearances and then traverse a model to apply the desired Appearance.
I have hit a bit of a snag as follows:
* once the Appearance is applied to an occurrence, I attempt to read back the occurrence.appearance.name I receive an error AttributeError: 'NoneType' object has no attribute 'name'
Refer approx line 71 in code below.
The API manual suggests an occurrence has an appearance property - that returns an appearance object - which has a corresponding name.  Note the processing of setting the new apperance functions successfully.
import adsk.core, adsk.fusion, adsk.cam, traceback
app = None
ui  = None
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        fileDialog = ui.createFileDialog()
        fileDialog.title = "Select Appearance File"
        fileDialog.isMultiSelectEnabled = False
        result = fileDialog.showOpen()
        if result != adsk.core.DialogResults.DialogOK:
            return
        else:
            filename = fileDialog.filename
        result = ui.messageBox('Yes = Create points from file\nNo = Update ponits from file',
                                'Control Points From File',
                                adsk.core.MessageBoxButtonTypes.YesNoCancelButtonType,
                                adsk.core.MessageBoxIconTypes.QuestionIconType)
        if result == adsk.core.DialogResults.DialogCancel:
            return
        elif result == adsk.core.DialogResults.DialogYes:
            ProcessAppearanceFile(filename)
        elif result == adsk.core.DialogResults.DialogNo:
            #UpdatePoints(filename)
            return
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def ProcessAppearanceFile(filename):
    try:
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        root = design.rootComponent
        occs = []
        ui.palettes.itemById('TextCommands').writeText("Debugging")
        occs = root.allOccurrences
        doc = app.activeDocument.name
        if len(occs) == 0:
            ui.messageBox('There are no components in this design.')
            return
        # Open the appearances file
        with open(filename) as f:
            for line in f:
                line = line.strip()
                appearances = line.split(',')
                componentName = appearances[0]
                componentAppearance = getAppearance(appearances[1])
                for occ in occs:
                    if occ.component.name == componentName:
                        occ.appearance = componentAppearance
                        # THIS IS LINE THAT FAILS
                        ui.palettes.itemById('TextCommands').writeText("New appearance " + occ.appearance.name)
                        # END OF LINE THAT FAILS
    except:
        if ui:
def getAppearance(appearanceName):
    materialLibs = app.materialLibraries
    appearance = None
    for materialLib in materialLibs:
        appearances = materialLib.appearances
        try:
            appearance = appearances.itemByName(appearanceName)
            ui.palettes.itemById('TextCommands').writeText(appearance.name)
        except:
            pass
        if appearance:
            break
    return appearance
9 REPLIES 9
Message 2 of 10
kandennti
in reply to: gvisca44
Hi @gvisca44 .
I am guessing because the CSV file was not attached, but I think that the CSV file is read as a normal text file and therefore the appearance is not being acquired properly.
(I think it is a double quotation marks issue).
I think you should add a filter to the dialog and use it in the csv module.
It would also be safer to check if the appearance is retrieved.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
import csv
app = None
ui  = None
def run(context):
    ui = None
    try:
        fileDialog: adsk.core.FileDialog = ui.createFileDialog()
        fileDialog.filter = 'csv files (*.csv);;'
            return
        else:
            return
            return
    except:
        if ui:
    try:
        occs = []
        app.log("Debugging")
        if len(occs) == 0:
            return
            reader = csv.reader(f)
            for row in reader:
                componentName = row[0]
                componentAppearance = getAppearance(row[1])
                if not componentAppearance:
                    msg = f'Canceled because "Appearance" cannot be obtained. \n ({row[1]})'
                    ui.messageBox(msg)
                    return
                for occ in occs:
                    print(occ.component.name)
                    print(componentName)
                        app.log("New appearance " + occ.appearance.name)
    except:
        if ui:
    appearance = None
        try:
            app.log(appearance.name)
        except:
            pass
        if appearance:
            break
    return appearance
Message 3 of 10
gvisca44
in reply to: kandennti
Hi @kandennti
I appreciate your response.  CSV file is as simple as component and desired appearance separated by comma per line.
I am happy that the application of the correct appearance is working because the appearances are visually present in the model I am working on.
I suspect (but am very happy to be corrected) something is screwy about accessing the appearance property of an occurrence object.
Consider the following code.  Getting the appearance by body by component works successfully.
However, getting the appearance by occurrence (which I believe should work) fails.  I can certainly SET the appearance this way.  And the occurrence object has an appearance property.
def getAppearanceByBody():
    for comp in design.allComponents:
        for body in comp.bRepBodies:
            app.log('Component-' + comp.name + '\tBody-' + body.name + '\tAppearance-' + body.appearance.name)
def getAppearanceByOccurrence():
    for occ in occs:
        app.log('Occurrence-' + occ.name + '\tAppearance-' + occ.appearance.name)
def run(context):
    ui = None
    try:
        ui.messageBox('APPEARANCES BY COMPONENT BODY')
        app.log('**** APPEARANCES BY COMPONENT BODY ****')
        ui.messageBox('APPEARANCES BY OCCURRENCE')
        app.log('****   APPEARANCES BY OCCURRENCE   ****')
    except:
        if ui:
            app.log('Failed:\n{}'.format(traceback.format_exc()))
Glenn.
Message 4 of 10
kandennti
@gvisca44 .
I understand what you mean.
Certainly the name property was not available in the case of Ocarens.
I think it is a bug.
How about using the id property?
Message 5 of 10
BrianEkins
The appearance property of the Occurrence object can return null. When an appearance is added to an occurrence, it overrides the colors assigned to the body and faces. Getting the occurrence appearance is getting the override color. If there isn't an override, it will return None.
Brian Ekins
Message 6 of 10
gvisca44
@kandennti
I had the same thought.  id also failed.
Message 7 of 10
gvisca44
in reply to: BrianEkins
@BrianEkins
yes ... after several hours of messing around I did finally get my head around the nuance.
However - my original statement remains ... when I apply an apperance to an occurrence it works successfully (can physically see it on the model).  When I attempt to read the appearance of that same occurrence - I receive the error.
Message 8 of 10
BrianEkins
Here's a small standalone script that I wrote to test this. Create a new design and create a new component (Occurrence) within the design and then run the script. Each time you run it, it will change the appearance of the occurrence from gold to steel and back. I'm also able to get the appearance after it's set.
def run(context):
    try:
        des = adsk.fusion.Design.cast(_app.activeProduct)
        root = des.rootComponent
        if root.occurrences.count == 0:
            ui.messageBox('There must be at least one occurrence in the design.')
            return
        occ = root.occurrences[0]
        app.log(f'Running test on {occ.name}')
        newName = 'Gold - Polished'
        if occ.appearance is None:
            app.log(f'  The occurrence has NO appearance override.')
        else:
            app.log(f'  The current appearance override is {occ.appearance.name}')
            if occ.appearance.name == 'Gold - Polished':
                newName = 'Steel - Satin'
        newAppearance = des.appearances.itemByName(newName)
        if newAppearance is None:
            lib = app.materialLibraries.itemByName('Fusion 360 Appearance Library')
            libAppearance = lib.appearances.itemByName(newName)
            newAppearance = des.appearances.addByCopy(libAppearance, newName)
        occ.appearance = newAppearance
        app.log(f'   After setting appearance the occurrence appearance is: {occ.appearance.name}')
    except:
Brian Ekins
Message 9 of 10
gvisca44
Thanks Brian
There's a small error in the script as posted:
note the underscore before app.activeProduct
But thats ok ... I think I have found the issue (more than likely in the way I am processing things)
Now - imagine you run that same script - but
You have a design with 1 occurence (as you state)
You have a design that uses the above as a linked design (which is the way all my designs operate).
Now run the script again on the second design.
Message 10 of 10
BrianEkins
That's it. I can reproduce it with a linked design. I'll see that a bug is filed.
Brian Ekins
