Announcements
Object Visibility Control
jsormaz
jsormaz
Is there a way to control the following through the API?
Instagram:
@sonsofsormaz
j4n.vokurka
unfortunately, there is no direct object in the API that you could use to edit these settings. However you can simulate navigating through the user interface and set the checkboxes to your liking. I used this workaround technique for effects of the camera.
This is a sample script that turns off sketches (unchecks the checkbox):
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        command_definitions = ui.commandDefinitions
        objectVisibilityCmdDef = command_definitions.itemById("VisibilityOverrideCommand")
        objectVisibilityControl = objectVisibilityCmdDef.controlDefinition
        objectVisibilityList = adsk.core.ListControlDefinition.cast(objectVisibilityControl)
        sketchesCheckBox = objectVisibilityList.listItems.item(8)  # turn off sketches
        if sketchesCheckBox.isSelected:
            was_turned_off = sketchesCheckBox.isSelected = False
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
jsormaz
good enough for me, thanks!
Instagram:
@sonsofsormaz
