I've been using Onur R. Bingol's very nice NURBS-Python package to do some NURBS-based curve fitting. I do the fitting in NURBS-Python (aka geomdl) and then just copy the parameters over into NurbsCurve3Ds for use inside Fusion 360.
Generally speaking, this works fine. However, I haven't been able to get a loop curve to port over correctly; Fusion 360 complains about the knot vector.
I thought, "No problem, I'll just look at some existing NurbsCurve3D loops and see exactly what they expect." But despite trying to emulate what I was getting from NurbsCurve3D.getData(), I still didn't have any luck creating a valid loop.
OK, all the above is background. Here's the crux of the issue: even if you feed back the exact data you receive from NurbsCurve3D.getData() to NurbsCurve3D.createRational(), it still doesn't work. The script below demonstrates. (And again, this is only for loops, aka periodic curves.)
getData() returns a control point vector that includes a duplicate of the first control point at the end of the list. Does createRational() expect this?
The knot vector also looks a bit odd. It starts with N zeroes (where N is the degree) which seems standard. But the end is just a single 1.0, which is different from the knots returned by nonperiodic curves.
Is there an example somewhere that shows a NURBS loop being created?
import adsk.core as core
import adsk.fusion as fusion
import traceback
points = [
core.Point3D.create(0.5, 0, 0),
core.Point3D.create(0, 0.5, 0),
core.Point3D.create(-0.5, 0, 0),
core.Point3D.create(0, -0.5, 0),
def toObjectCollection(iterable):
collection = core.ObjectCollection.create()
for item in iterable:
collection.add(item)
return collection
def run(context):
try:
app = core.Application.get()
root = app.activeProduct.rootComponent
# Create sketch and curve loop
sketch = root.sketches.add(root.xYConstructionPlane)
fittedSplines = sketch.sketchCurves.sketchFittedSplines
spline = fittedSplines.add(toObjectCollection(points))
spline.isClosed = True
nurbsCurve = spline.geometry
# Harvest NURBS parameters
ok, controlPoints, degree, knots, rational, weights, periodic = nurbsCurve.getData()
# Verify that parameters are as expected
assert ok, "Unable to read NURBS data"
assert len(controlPoints) == 25, "Unexpected number of control points"
assert controlPoints[0].isEqualTo(controlPoints[-1]), "First and last point not equal"
assert degree == 5, "Unexpected degree"
assert len(knots) == len(controlPoints), "nControlPoints != nKnots"
assert all(w == 1.0 for w in weights), "Some weights not 1.0"
assert periodic, "Unexpected nonloop curve"
# Copy all arrays and points, just to verify that this is not the issue
controlPoints = [point.copy() for point in controlPoints]
knots = [knot for knot in knots]
weights = [weight for weight in knots]
# Throws "RuntimeError 3: Invalid argument controlPoints"
dupCurve = core.NurbsCurve3D.createRational(controlPoints, degree, knots, weights, periodic)
except:
if app.userInterface:
app.userInterface.messageBox('Failed:\n{}'.format(traceback.format_exc()))
