Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Numpy import error
1 REPLY 1
jc42shcool
214 Views, 1 Reply
Numpy import error
Hello, I have a difficult time importing Numpy...
I know there are a lot of posts about importing Numpy error. I was able to fix it by using the site-packages install method to my local folder Module. However, today it somehow cannot find the Numpy again. I was wondering is it possible to have Numpy package inside the fusion 360 API? Therefore, the user can just import Numpy directly.
Thank you
Jeff
1 REPLY 1
goyals
in reply to: jc42shcool
Fusion comes with standard python package and I do not think there is any plan to include any new module in it. But generally approach of having site-package in your script directory should work. May be you can try to check if your script folder is included in python search path or not using below script.
import sys
sys.path
Shyam Goyal
Sr. Software Dev. Manager
