Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
No "Project to Surface" in the API?
1 REPLY 1
Jonschke
184 Views, 1 Reply
Hey,
i looked into the API and didnt find the API equivalent to the "Project to Surface" command, which is available through the gui.
Is this correct, that i can´t "Project to Surface" with the scripting interface?
1 REPLY 1
ekinsb
in reply to: Jonschke
Unfortunately, you're correct and this is not currently supported by the API.  However the design is fished and the implementation work is already on our backlog so it's just a matter of when it can be done, which I don't know at this point.
Brian Ekins
Mod the Machine blog
