Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
no add-in(s) are working.
2 REPLIES 2
jonedvardk
197 Views, 2 Replies
i've installed a few add-ins - and none of them are working.  the installs were a (.msi)
it shows up on the menu - but i'm unable to run them inside fusion. Smiley Sad
jón
2 REPLIES 2
gregor.stupica
in reply to: jonedvardk
if there is circle next to it, it means that is working.
Normaly it shows new button somewhere in the Toolbar
jonedvardk
in reply to: gregor.stupica
hey thanks.
well - still nowhere to be found. it should be found here i presume (this image from the developer) but mine is empty! is there a setting somewhere that disables it somehow?
