Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
New script for custom Thread Resizing
1 REPLY 1
valentinimarko
149 Views, 1 Reply
I just made available to the public a python script able to automatically resize all Thread in Fusion 360 by a fixed amount.
the source code is now for mac but can be easily adjusted to pc with small modifications in the code, you can find it in my github account:
https://github.com/mava70/fusion360scripts
after running the script all xml Thread files in production installation of Fusion 360 on your pc will be duplicated with same filename+RESIZED.xml, and you can find the new Thread type directly in Fusion 360.
I am planning to do a video guide, but I think the script are simple.
The script is based on the following knowledge base
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Custo...
video explanation here:
https://youtu.be/1hn4vYDwGYU
Italian but with english subtitle
Bye
Marco
1 REPLY 1
You can find a multiplatform solution to manage the Fusion 360 installation path here: https://github.com/JeromeBriot/fusion360-open-folders/blob/main/OpenFolders.py
