Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Need help with biscuit slots along centre line of face
2 REPLIES 2
markQAJZF
191 Views, 2 Replies
I use a lot of size 20 biscuits for cabinet construction. Currently I model each biscuit slot with a sketch on the edge of a panel, patterened along the length of the joining edge and then extrude-cutting each biscuit rectangle into the 2 joining bodies. I've had good success using parameter tables to semi-automate the process but its only just quicker to do all the modelling and programming for CNC than it is for a maker to do by hand.
 I have very little programming knowledge. Is there a script that exists that can quickly create this pattern? I'm picturing a userform than needs two edges to be selected, and a number of biscuits to be specified, and then the script will find the centerline between the 2 edges and cut the slots. Happy to employ the services of a coder to help me out here. Thanks
2 REPLIES 2
kandennti
in reply to: markQAJZF
Hi @markQAJZF -San.
I can't start working on it right away, but I can make it.
Since we don't know the details, could you please attach an f3d file that we can publish?
Jorge_Jaramillo
Hi @markQAJZF ,
I will be available the next two days is you think I can help developing the script.
It will be just a matter of define the scope of it.
Looking forward hearing from you.
Jorge Jaramillo
