Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Need Expert Guidance
0 REPLIES 0
Message 1 of 1
john4TMYX
53 Views, 0 Replies
Hi guys,
I have a 3D mesh surface. I need to flatten this mesh surface and save the result into XY Plan.  What I did is to create a sketcher and save the lines into the sketcher. The Fusion has the sketcher in the model tree. It works fine for most of my cases. However, if I have a mesh lines over 10000, then Fusion 360 will crash. Basically if I want to save 10k short lines into a sketch, Fusion will crash. Does anyone have a better idea how to save the mesh data into Fusion?
Thank you.
Regards
John
0 REPLIES 0
