Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
NC Program G-code modification
2 REPLIES 2
KJammin
221 Views, 2 Replies
Dear users,
Hello. I am trying to post-process the adaptive milling process I have created to G-codes.
I was wondering if I can specify the setting so that the code only contains the G1 commands rather than G2 and G3 commands. I know circular motions cannot be expressed 100% with linear motions, but it would be great if there is any way I can use functions to generate the code. Thank you so much in advance!
2 REPLIES 2
kandennti
in reply to: KJammin
Hi @KJammin .
I think it would be better to ask this question in the Fusion 360 Manufacture forum.
https://forums.autodesk.com/t5/fusion-360-manufacture/bd-p/2070
If you only want G1, just set the "Maximum circular radius" to a smaller value.
KJammin
Dear kandennti,
Thank you so much for your support.
The resulting NC program is exactly what I wanted.
Hope you have a good week!
Many thanks
Kyung Ha Lee
