Announcements
Name of the current configuration?
thomasa88
thomasa88
Hi, is there a way to read the name of the currently active configuration in a document?
Browsing the documentation, I can't find a function for it.
kandennti
Hi @thomasa88 -San.
I searched for it and was able to get it this way.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        if not des.isConfiguredDesign: return
        configTopTable: fusion.ConfigurationTopTable = des.configurationTopTable
        actRow: fusion.ConfigurationRow = configTopTable.activeRow
        ui.messageBox(actRow.name, "Active Configuration Name")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
thomasa88
Thank you, @kandennti ! You are a scripting expert!
I will try this out 🙂
