Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
MyDocumentOpenedHandler - Problem
1 REPLY 1
isocam
96 Views, 1 Reply
Can anybody help?
Please see the attached script.
I am using "MyDocumentOpenedHandler" to check if a PDF copy of a drawing exists when I open a drawing.
If I put a ui.messageBox into the script the PDF file is successfully created!
If I remove the ui.messageBox Fusion 360 "hangs up" and I have to close Fusion 360.
Does anybody know what I am doing wrong, or how to correct this, or is this a possible bug???
Many thanks in advance!
Darren
1 REPLY 1
kandennti
in reply to: isocam
Hi @isocam.
I don't understand the question, but I will describe what I know about the documentOpened event.
It seems that the documentOpened event is fired when the command is finished, not when the document is completely opened.
You can see a sample of how I picked up the timing of the document opening from the task in the past.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/drawing-pdf-export-how-to-access-the-new-e...
