Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Multiple selection inputs
4 REPLIES 4
p_krola
170 Views, 4 Replies
My Add in has two SelectionInputs. I have a problem checking which SelectionInput has been selected. How do I use activeInput ()?
class MySelectHandler : public SelectionEventHandler
public:
	void notify(const Ptr<SelectionEventArgs>& eventArgs) override
		if (!eventArgs)
			return;
		Ptr<Selection> selection = eventArgs->selection();
		if (!checkReturn(selection))
			return;
		// Get the value of the property.
		Ptr<SelectionCommandInput> propertyValue = selection->activeInput();
4 REPLIES 4
Jorge_Jaramillo
in reply to: p_krola
Hi @p_krola ,
You can get the ID of the commandInput that fires the event with the id() property like so:
selection->activeInput()->id()
It returns a string.
Jorge
p_krola
in reply to: Jorge_Jaramillo
The function at SelectionEventHandler generates an error:
_app->log(selection->activeInput()->id());
E0135 class "adsk::core::Selection" has no member "activeInput"
I can get inputId from InputChangedEventHandler, but that doesn't solve my problem.
Ptr<CommandInput> changedInput = eventArgs->input();
std::string activeInput = changedInput->id();
Jorge_Jaramillo
I made a mistake in the previous answer.
It is like so:
Ptr<SelectionCommandInput> cmdInput = eventArgs->activeInput();
string id = cmdInput->id()
Lets try it.
Jorge
BrianEkins
I also recently ran into this problem. It seems there's a bug with the activeInput property. The workaround I ended up using is to check the hasFocus property of each of the SelectionCommandInput objects on my dialog. The one where this is true is the one that they are using.
Brian Ekins
