Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
MS Code - Python extension exception
2 REPLIES 2
balunist
303 Views, 2 Replies
Running the latest Python extension I consistently get the following exception.   Has anyone else experienced this?
No breakpoints are set and this occurs shortly after a successful startup of my app.
Thanks in advance!
Exception in thread ptvsd.Server: Traceback (most recent call last): File "/Users/<userid>/.vscode/extensions/ms-python.python-2020.6.90262/pythonFiles/lib/python/old_ptvsd/pt...", line 269, in process_one_message msg = self.__message.pop(0) IndexError: pop from empty list
Labels (1)
2 REPLIES 2
Rushikesh.kadam
in reply to: balunist
Hi @balunist , this issues looks to be similar to https://forums.autodesk.com/t5/fusion-360-api-and-scripts/vs-code-upgrade-to-the-latest-python-exten..., can you try if the mentioned solution works for you also?
Rushikesh Kadam.
If my reply was helpful, please give a "Like" or click the "Accept as Solution" button below (or both).
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
balunist
in reply to: Rushikesh.kadam
I deleted the extension as described and allowed Fusion to install by invoking debug.   They installed the latest version.   I included a fusion restart before and after.    I’m still seeing the same exception pop up after seeing my app successfully start.
So no change occurred and it did not fix the problem.
