Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Moving selected bodies to a single new component
6 REPLIES 6
darran
812 Views, 6 Replies
I have a component with lots and lots of constituent bodies. I'm trying to write a script – and its my first so please bear with me – that moves all currently selected bodies into a new component under the root level. For example, I want to be able to click on a handful of bodies out of the many, run the script and see a new component created with the selected bodies now moved within this new component.
It seems pretty straight forward. And I can do it in Python via the "View | Text Commands" dialog. But I can't reliably do it via the script below. Sometimes it works ... and then on the next selection and run, it doesn't. It doesn't help that I can't seem to log the script output to aid in debugging.
Can someone please take a look and point out my error?
from adsk.core import *
from adsk.fusion import *
import traceback
try:
    app = adsk.core.Application.get()
    ui  = app.userInterface
    design = adsk.fusion.Design.cast(app.activeProduct)
    root = design.rootComponent
    # empty list to contain references to selected bodies
    bodies = []
    # iterate over all selections (which may or may not be Bodies)
    for selection in ui.activeSelections:
    	entity = selection.entity
    	if entity.objectType == adsk.fusion.BRepBody.classType():
            bodies.append(entity)
    # if there are bodies to move, create a new child component under the top level
    if len(bodies):
        occurence = root.occurrences.addNewComponent(adsk.core.Matrix3D.create())
        occurence.isLightBulbOn = False
        for body in bodies:
    		body.moveToComponent(occurence)
except:
    ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
6 REPLIES 6
kandennti
in reply to: darran
Hi @darran .
Requires a "run" function.
import traceback
def run(context):
    try:
darran
in reply to: kandennti
Hmm, I thought use of the run function was only required for Add-ins, and was optional for Scripts. Anyway, I've updated the code to that shown below. Unfortunately I wasn't seeing anything happen when launching the script ... so I added the messageBox to get some visual feedback. And it doesn't show either ... which makes me think that either (i) Fusion isn't picking up the changes to the script; or (ii) there's a syntax error in the script that prevents execution.
import traceback
def run(context):
    ui.messageBox("Here we go ...")
    try:
        # empty list to contain reference to selected bodies
        bodies = []
        if len(bodies):
            for body in bodies:
    except:
darran
in reply to: darran
Okay, I found and resolved the issue ... but I don't really understand why it happens. The issue is trying to add entity objects to a python list that isn't created as a global variable. Here's the code that now works:
import traceback
# for some reason this needs to be a global variable
bodies = []
def run(context):
    try:
        if len(bodies):
            for body in bodies:
    except:
I can't see anything implying that the above is required in the Python-specific documentation.
adminTCYL2
in reply to: darran
This is a nice peace of code and I used it to bring lots of bodies out of a component in lots of new occurences each for one body.
But I want to give the new components the name of the bodies (they are all named).
How can I do this?
And why does the code not run without that bodies-array?... (the two lines that I comanded out.)
bodies = []
            for i in range(0,len(new_component.bRepBodies)):
                body = new_component.bRepBodies[i]
                #bodies.append(body)
            #for body in bodies:
                occurence = root_comp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
                _ui.messageBox(body.name)
BrianEkins
in reply to: adminTCYL2
I don't know what the original problem with the list was because when I try the original code it works fine for me.
As far as setting the name of the new component just add the second line shown below.
occurence.component.name = body.name
Brian Ekins
adminTCYL2
in reply to: BrianEkins
I found a working way by myself now. The failure seems the i in new_component.bRepBodies[i]
What I do is: I take 5 Bodies that are in a box named "new_component" in five seperat boxes.
So I take the first and put it in the first box.
Now I say: "take the second and put it in the second box"--- but the computer takes the third. Why? Because there are only 4 Bodies in the box anymore and the second of these was the third at the beginning.
The right way is allways to take the first named new_component.bRepBodies[0]
Here is the corrected skript:
def BodiesToComponents():
    j = len(new_component.bRepBodies)
    for i in range(0,j):
        body = new_component.bRepBodies[0]
        new_occurrence = root_comp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
        new_occurrence.component.name = body.name
        body.moveToComponent(new_occurrence)
