Announcements
Moving focus
brad.bylls
Moving focus
brad.bylls
When using the combine command, when the user selects the target body the focus automatically shifts to the tools selection box.
I have a similar UI and would like to know how that focus shift is done.
I tried the tab key but that does not work.
Thanks.
Brad Bylls
nnikbin
@brad.bylls, in InputChangedEventHandler you can watch the changes of your SelectionCommandInput objects and if one of them changes and its selectionCount is greater than 0, switch the focus to the next SelectionCommandInput using SelectionCommandInput.hasFocus Property
brad.bylls
Thanks for the input (pun intended 8^)
I understand what you are saying, but I don't know how to code it.
Can you help.
    def on_input_changed(selfcommandinputschanged_inputinput_values😞
        if changed_input.id == 'target':
            selection_input = inputs.itemById('tool')
            selection_input.hasFocus
. . . . . . . . . . . . more code . . . . . . . . . . . .
        # Create the command dialog
        _inputSelectTargets = inputs.addSelectionInput('target''Select The Target Body''Select the Body\nThat Will Be Cut')
        _inputSelectTargets.addSelectionFilter(adsk.core.SelectionCommandInput.Bodies)
        _inputSelectTargets.setSelectionLimits(11)
        _inputSelectTools = inputs.addSelectionInput('tool''Select The Tool Bodies''Select the Bodies\nThat Will Do The Cutting')
        _inputSelectTools.addSelectionFilter(adsk.core.SelectionCommandInput.Bodies)
        _inputSelectTools.setSelectionLimits(0)
Brad Bylls
brad.bylls
Of course just after sending you the reply, I figured it out.
Thanks for the help and pointing me in the right direction.
Brad Bylls
