Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Moving a sketch dimension with the Fusion API
1 REPLY 1
autodesk.comGX2RW
110 Views, 1 Reply
I would like to create an addin that let's me snap a dimension to the grid.
The problem is that Fusion 360 is crashing when I am trying to set SketchDimension.textPosition. Setting textPosition.x or moving the textPosition with textPosition.translateBy does not crash Fusion but also doesn't change the position of the dimension.
The code that is crashing Fusion is the following (I've attached the complete code of the addin).
from adsk.core import *
from adsk.fusion import *
app = Application.get()
ui = app.userInterface
selections = ui.activeSelections
for i in range(0, selections.count):
    selection = selections.item(i)
    dimension = selection.entity
    if isinstance(dimension, SketchDimension):
        dimension.textPosition = Point3D(10, 10, 10)
Is there anything I am doing wrong or is this a bug in Fusion?
1 REPLY 1
I'm able to reproduce the crash with a very simple test case. I'll make sure a bug is logged.
Brian Ekins
