Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Moving a sketch circle tangent too two projected arcs
2 REPLIES 2
rusty.bird
148 Views, 2 Replies
I made a script to move a sketched circle tangent between two projected arcs but it is not moving when I run it.  Can anybody help me figure out why its not working properly?   I have attached some pictures and the file aswell.
Here is my script:
	// Prompt the user to select a plane.
	Ptr<Selection> selection1 = ui->selectEntity("Select a Face On the Rolls", "Faces");
	Ptr<BRepFace> plane1 = selection1->entity();
	// Get the selected face and create a sketch on it
	Ptr<Sketches> skt = rootComp->sketches();
	Ptr<Sketch> skt1 = skt->addWithoutEdges(plane1);
	Ptr<SketchCurves> curves = skt1->sketchCurves();
	Ptr<SketchCircles> circles = curves->sketchCircles();
	// Create a circle with a diameter
	Ptr<SketchCircle> circle1 = circles->addByCenterRadius(Point3D::create(0, -30, 0), 20);
	if (!circle1)
		return false;
	Ptr<SketchDimensions> dims = skt1->sketchDimensions();
	// Add the dimension to the circle
	Ptr<SketchDimension> dim1 = dims->addDiameterDimension(circle1, adsk::core::Point3D::create(0, 0, 0));
	if (!dim1)
		return false;
	// Prompt the user to select a bRepEdge.
	Ptr<Selection> selection2 = ui->selectEntity("Select The Round Edge On A Roll", "Edges");
	Ptr<BRepEdge> edge1 = selection2->entity();
	Ptr<SketchCurve> proj1;
	proj1 = skt1->project(edge1);
	// Prompt the user to select another bRepEdge.
	Ptr<Selection> selection3 = ui->selectEntity("Select The Other Round Edge On A Roll", "Edges");
	Ptr<BRepEdge> edge2 = selection3->entity();
	Ptr<SketchCurve> proj2;
	proj2 = skt1->project(edge2);
	Ptr<GeometricConstraints> constraints = skt1->geometricConstraints();
	Ptr<GeometricConstraint> tanCon1 = constraints->addTangent(circle1, proj1);
	if (!tanCon1)
		return false;
	Ptr<GeometricConstraint> tanCon2 = constraints->addTangent(circle1, proj2);
	if (!tanCon2)
		return false;
2 REPLIES 2
Your problem is with variables proj1 and proj2.
This sentence:
returns an ObjectCollection and you are expecting a SketchCurve as the proj1 variable was declared.
You need to change this sentence by:
proj1 = skt1->project(edge1)->item(0);
The same fix need to be made for proj2.
It solved the problem in my tests.
Jorge Jaramillo
Yes this worked.  Thanks
