Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Move brepFace in parametric design
2 REPLIES 2
PinRudolf
298 Views, 2 Replies
I'm trying to move a brepFace but I'm having some trouble understanding how to do this. I would like to move a face but keep the body as a whole, I would also like to be able to rotate the face. Basically I want the option Move from the Modify menu.
Using the API-documentation I've looked into different methods but they all do not seem be suited for one reason or another.
  • MoveFeatures gives me exactly what I want, except that it only works for faces in non-parametric modeling.
  • Using OffsetFeatures I could create a new face but will then have to connect that new face to the previous face, creating at least 2 more features. Also it won't help me do a rotation. (Not similar to the menu OffsetFaces in the way I expected it to be.)
  • The brepFace object has the property Geometry which will return a Surface, which then has a method transformBy. Which is great except that the Geometry property is read only and nothing happens. The same counts for moving vertices.
Now I am wondering if I am going about this all wrong or if this option is just not available?
I've come across this exact same requirement before and just found a way to work around it, but now I'm running into it again I start to feel like I'm missing something obvious.
Thanks!
Tags (3)
2 REPLIES 2
Ruud1
in reply to: PinRudolf
Extrude to object will move and rotate the face 🙂
PinRudolf
in reply to: Ruud1
I have overlooked the simplest solution of all! 😄 This will suit my current project nicely.
(Yet it is only a coincidence that I actually have a face to extrude to.)
Technology Administrators
