Hi all,
I've put together a script called "moveMultBodiesinList" that I would like to use to translate and rotate a body(s) with. When you run the script I posted below with these variables: moveMultBodiesinList([body],90,20,0,0,'XY'), it will perform the rotation but not move. If I set rotation to 0 it will move the body using the x,y,z values.
Can someone tell me why this script will only work for just a rotation, or just a move, but not both at the same time?
If you copy and paste the code below into a python module and run it you will see that it rotates the selected body but does not move it. If you set the rotation to 0 and run it you will see the translation occur.
Thanks for the help!!
Eric
import adsk.core, adsk.fusion, traceback,math
def selectEnt(msg: str,filtterStr: str) -> adsk.core.Selection:
try:
app = adsk.core.Application.get()
ui = app.userInterface
sel = ui.selectEntity(msg, filtterStr)
#get the BRep from the selection (Programming Interface Fusion 360 API User's Manual Selection Filters)
if filtterStr == 'Faces':
face = adsk.fusion.BRepFace.cast(sel.entity)
return face
elif filtterStr == 'Bodies':
body = adsk.fusion.BRepBody.cast(sel.entity)
return body
elif filtterStr == 'SolidBodies':
comp = body.parentComponent
#comp.saveCopyAs()
return body
elif filtterStr == 'Edges':
body = adsk.fusion.BRepEdge.cast(sel.entity)
return body
elif filtterStr == 'SketchPoints':
body = adsk.fusion.SketchPoint.cast(sel.entity)
return body
elif filtterStr == 'Vertices':
body = adsk.fusion.BRepVertex.cast(sel.entity)
return body
elif filtterStr == 'Occurrences':
body = adsk.fusion.Occurrence.cast(sel.entity)
return body
else:
return sel
except:
return None
def GetBB_Mult(bodies):
"""Calculates the bounding box coordinates of the selected objects and returns the following in order:
X_Min,Y_Min,Z_Min,X_Max,Y_Max,Z_Max,length_X,length_Y,length_Z,mid_X,mid_Y,mid_Z"""
#Set initial values for Max and Min
MaxDouble = 1.79769313486231e10
MinDouble = -1.79769313486231e10
# Initialize to large/small values
X_Max = MinDouble;X_Min = MaxDouble;Y_Max = MinDouble;Y_Min = MaxDouble;Z_Max = MinDouble;Z_Min = MaxDouble
for i in bodies:
#Get Bounding Box
box = i.boundingBox
# XMin = box[0][0];YMin = box[0][1];ZMin = box[0][2];XMax = box[6][0];YMax = box[6][1];ZMax = box[6][2]
XMin = box.minPoint.x
YMin = box.minPoint.y
ZMin = box.minPoint.z
XMax = box.maxPoint.x
YMax = box.maxPoint.y
ZMax = box.maxPoint.z
#Check for Min/Max Values
if XMin <= X_Min:
X_Min = XMin
if YMin <= Y_Min:
Y_Min = YMin
if ZMin <= Z_Min:
Z_Min = ZMin
if XMax >= X_Max:
X_Max = XMax
if YMax >= Y_Max:
Y_Max = YMax
if ZMax >= Z_Max:
Z_Max = ZMax
#Calculate L,W,H
length_X = X_Max - X_Min
length_Y = Y_Max - Y_Min
length_Z = Z_Max - Z_Min
#Calc Mid Point
mid_X = X_Min + ((X_Max-X_Min)/2)
mid_Y = Y_Min + ((Y_Max-Y_Min)/2)
mid_Z = Z_Min + ((Z_Max-Z_Min)/2)
return X_Min,Y_Min,Z_Min,X_Max,Y_Max,Z_Max,length_X,length_Y,length_Z,mid_X,mid_Y,mid_Z
def moveMultBodiesinList(bodLst,angle,x,y,z,refPlane):
"""This function will move a single body. x,y and z should be in cm.
ui = None
try:
inputEnts = adsk.core.ObjectCollection.create()
for body in bodLst:
inputEnts.add(body)
#create the Matrix3D
mat = adsk.core.Matrix3D.create()
#set the rotation
angle = math.radians(angle)
# return X_Min,Y_Min,Z_Min,X_Max,Y_Max,Z_Max,length_X,length_Y,length_Z,mid_X,mid_Y,mid_Z
BB = GetBB_Mult(bodLst)
ctr = adsk.core.Point3D.create(BB[9],BB[10],BB[11])
if refPlane == 'YZ':
rot = adsk.core.Vector3D.create(1,0,0)
#define the vector
if (y != 0.00) or (z != 0.00):
vector = adsk.core.Vector3D.create(x, y, z)
mat.translation = vector
if refPlane == 'XZ':
rot = adsk.core.Vector3D.create(0,1,0)
#define the vector
if (x != 0.00) or (z != 0.00):
if refPlane == 'XY':
rot = adsk.core.Vector3D.create(0,0,1)
#define the vector
if (x != 0.00) or (y != 0.00):
if angle != 0:
rotate = mat.setToRotation(angle, rot, ctr)
#make the move
try:
moveInput = body.parentComponent.features.moveFeatures.createInput(inputEnts, mat)
body.parentComponent.features.moveFeatures.add(moveInput)
except:
pass
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# #Select body
body = selectEnt('Select Body','Bodies')
