Announcements
mouseWheel event only fires after the user clicks the mousewheel
Joshua.mursic
Joshua.mursic
Is anyone else having an issue where the mouseWheel event only starts to fire after the user has clicked the mouse wheel? Here is a test script.
import adsk.core, adsk.fusion, adsk.cam
app = adsk.core.Application.get()
ui = app.userInterface
handlers = []
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args:adsk.core.CommandCreatedEventArgs):
        cmd = args.command
        cmd.isExecutedWhenPreEmpted = False
        inputs = cmd.commandInputs
        textInput = inputs.addTextBoxCommandInput('textBoxId', 'Wheel Test', 'Test the wheel', 1, True)
        # Connect to the command related events.
        mouseWheelEvent = MyMouseScrollHandler(textInput)
        cmd.mouseWheel.add(mouseWheelEvent)
        handlers.append(mouseWheelEvent)
class MyMouseScrollHandler(adsk.core.MouseEventHandler):
    def __init__(self, textInput):
        super().__init__()
        self.input:adsk.core.TextBoxCommandInput = textInput
    def notify(self, args: adsk.core.MouseEventArgs):
        self.input.formattedText = f'Wheel Delta = {args.wheelDelta}'
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        adsk.terminate()
def run(context):
    cmdId = "testWheel"
    cmd_def = ui.commandDefinitions.itemById(cmdId)
    if cmd_def is not None:
        cmd_def.deleteMe()
    cmd_def = ui.commandDefinitions.addButtonDefinition(cmdId, "Test Wheel", '', '')
    # Connect to the command created event.
    onCommandCreated = MyCommandCreatedHandler()
    cmd_def.commandCreated.add(onCommandCreated)
    handlers.append(onCommandCreated)
    # Execute the command.
    cmd_def.execute()
kandennti
Hi @Joshua.mursic -San.
I use a cheap scrolling mouse and the event occurred without clicking the wheel.
Joshua.mursic
Thank you @kandennti, I will buy a different mouse.
