Announcements
Modify Holes
Modify Holes
Hello, I am trying to create a script to edit the parameters of an existing hole, I try to access it through its name in the example parameter list "Hole1".
I have been able to create the holes, but I cannot modify them. Can someone give me an idea ?
Thank you!
goyals
May be you can try something like this.
app = adsk.core.Application.get()
root = app.activeProduct.rootComponent
features = root.features
holeFeatures = features.holeFeatures
hole = holeFeatures[0]
diaParam = hole.holeDiameter
diaParam.value = 3.2
Shyam Goyal
Sr. Software Dev. Manager
Thank you very much goyals, I will start there !
Hello! First of all, to say that I don't know if it is correct to publish this here or elsewhere, I will do it where you indicate.
I am very interested in continuing studying .. I have managed to carry out various tests, create objects, etc.
Something that I can't do is, as in the previous case, with an existing hole, for example. vary its depth .. if the diameter, modify its name, add comments, etc.
Is there a book or study material that contains clear information about your programming?
Could you give me, as in the previous case, a basic example of how I modify the depth of an existing hole?
Thank you very much, I think this confinement is affecting me!
goyals
The good reference to learn is API documentation. Multiple samples are also provided here to get you started with initial code. http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-DE98632B-3DC0-422B-A1C6-8A5A15C99E11
Some Fusion API concepts are explained also on https://modthemachine.typepad.com. I hope this will help. Take care.
Shyam Goyal
Hello, thank you very much for your answer !
Those links you passed me I have seen and studied a lot, hence I managed to perform many of the tests, along with "tapnair" work among others ..
What I can not find and even in these links that you passed me, is how to modify the depth of an existing drilling, if created from scratch but not existing.
I am programming and debugging with VSCode which is very helpful ..
I will continue investigating, if you have the opportunity to pass me an example of how the depth of the hole is handled, I would appreciate it!
Cheers
Hello, thank you very much .. I already did it ..
It would be great if there was more and better information about this API. I have been programming for many years and after studying various things and debugging the code I managed to get to this ..
Regarding the help information, it is almost impossible to understand what parameters refer to a function.
We will continue studying!
Thank you so much !
