Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Missing documentation for CustomGraphicsBRepFaces and CustomGraphicsBRepEdges
4 REPLIES 4
nnikbin
369 Views, 4 Replies
CustomGraphicsBRepBody.faces property returns a CustomGraphicsBRepFaces object and CustomGraphicsBRepBody.edges property returns a CustomGraphicsBRepEdges object, but the documentation pages for these types are missing.
The only information about them in Fusion 360 help is that they are read only collections of CustomGraphicsBRepFace and  CustomGraphicsBRepEdge objects, but It seems they do not provide properties and methods of collection objects (like item and count). Also the documentation and header files for CustomGraphicsBRepFace and CustomGraphicsBRepEdge are unavailable.
Tags (1)
Labels (2)
4 REPLIES 4
BrianEkins
in reply to: nnikbin
It's a mistake that they are showing up at all.  I had defined them in the specification and apparently, the implementation work was started enough to define the objects but they were never implemented.  The only thing related to B-Rep and custom graphics that currently supports is the CustomGraphicsBRepBody.
Brian Ekins
nnikbin
Thank you @BrianEkins for the information.
felix85SA3
The edges and faces properties are still part of the CustomGraphicsBRepBody, with missing references inside of the refs fusion.py and linked within the API documentation. Are there any plans to get rid of those loose ends?
BrianEkins
in reply to: felix85SA3
They should either be removed or implemented. Usually, removing anything is avoided in case someone calls it, but I think there's no risk in this case since it doesn't work.
Brian Ekins
