Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
MessageBox Ver. 2.0.10027
6 REPLIES 6
kandennti
404 Views, 6 Replies
Hi everyone.
It seems that UserInterface.messageBox has been changed since Ver 2.0.10027.
I cannot drag the displayed MessageBox with the mouse, is this a specification?
It used to be possible to drag them.
It is operated at 0:08-0:09.
6 REPLIES 6
JeromeBriot
in reply to: kandennti
I confirm that the messageBox object change and is no more movable:
ui.messageBox('test', 'Test Message box')
goyals
It is as per specification at the moment. We are trying to make message box in Fusion more HIG compliant. There will be more changes to the styling of this dialog in next Fusion update. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
kandennti
in reply to: goyals
Thank you, @goyals .
Yes, sir. I'm looking forward to it.
If I really need the old style, I will use this.
def run(context):
    ui :adsk.core.UserInterface = None
    try:
        app :adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        msg = 'New Style'
        ui.messageBox(msg)
        msg = 'Old Style'
        app.executeTextCommand(f'UI.SimpleMessageBox "{msg}"')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
We have confirmed that Ver 2.0.10244 fixed the problem so that you can move it by dragging.
Thanks!
JeromeBriot
Did you notice that you can now select text and copy/paste it using the right mouse button or keyboard shortcuts?
Thanks to whoever implemented this.
nnikbin
in reply to: JeromeBriot
Like the pre-modernized version, the new message box is able to show basic html formatting (an undocumented feature).
Running @JeromeBriot 's code from this post results the following message box.
And by copyig the html formatted text, you can paste it as formatted text, for example in a google docs document.
