meshBody export
MichaelT_123
meshBody export
MichaelT_123
Hi TF360,
returnValue = exportManager_var.createSTLExportOptions(geometry, filename)
gives provision to export the following entities.
geometry
Base
The geometry to export. This can be a BRepBody, Occurrence, or Component object.
I have tried to export meshBody, which is not on the list and despite  returnValue = True , no respective file is created. Nevertheless, the mesh body can be successfully saved by the user interface command, indicating that the software code underlying the process is in place.
Would it be possible to add meshBody to the list of STL exports? … if not in this year, then the next one? Currently, I am running my custom export process … but certainly, the one implemented by TF360 will be more … elegant.
HNY & Regards
MichaelT
MichaelT
Replies (0)
